changed my alternator
removed driveshaft and shift assembly
Flushed brake fluid with a Mity-Vac, took 3.5 to 4 ozs from each caliper. Then searched and found I needed to draw 8 from the rears and 5 from the fronts. Used up all my DOT 4, so I can't redo it, but the pedal does feel better. Also washed the whore, as my wife refers to it.
installed DDM coil-overs
About to go and do clutch pedal bushings.
replaced microfilter, good engineering on that one BMW.
california dusted her,adjusted the e-brake,lamin-x fog lamps
99 328is daily 97 328is Track Baby
Brought my bumper to the body shop for a repaint and get some special things done...
and look at it thinking why the fuck do i do what i do for you...:idk:
BMW - MagnaFlow - K&N - Beyern - Depo
- Pic Comming Soon -
Cleaned and conditioned the leather seats w/ Lexol.
Engine: M3 (S52) motor | AA C38 stg 1 Supercharger | MLS HG + ARP studs | M50 manifold | UUC motor and tranny mounts
Drivetrain: 3.38 LSD | UUC stg 2 clutch | UUC 8.5 lb flywheel | SS Clutch line | Z3 steering rack | M3 brakes | SS brake lines
Suspension: X-Brace | Bilstein BTS | PowerFlex RTABS | Exhaust: AA track pipe | AA Gen III Exhaust
Misc: Euro G4 Ellipsoids-Ultra HD 60+ LED eyes | Euro 3-Spoke steering wheel | tan Vaders |CD43 player
i drove it.
Removed both front wheels...cleaned the backs of both of them...realized I'll need front pads soon...cleaned/dressed the wheel wells...didn't have time to install the BW Camber Shim Kit...
Also, from a post on here, spray a little WD-40 on the aggravating, non-closing, fuel door hinges/spring...and it worked!
Todd Owenby
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But, above all, try something."
Franklin Delano Roosevelt, May 22, 1932
Tried to install new front struts (Bilstein Touring) but the bumpstop on one old strut was FUBAR. On the other strut it was missing! So I ordered new bumpstops ($4.95 ea from NAPA) and they'll be here on Wednesday...
Fixed my drivers window. WOOHOO!
Took 2 hrs. but 0 $
added info on the window motor DIY
went and flogged it just so i could listen to my new muffler
http://www.facebook.com/v/94298916643
(thats dad driving it so i could listen to it)
its a magnaflow with custom junB.L tips
imagined it with the suspension upgrade I'm doing next week
nothing really significant. cleaned it, took the hood off, took photos then blew the hood shocks while trying to put the hood back on
Put Tein M3 lowering springs on my 328i. Then washed it.
Washed it ... because driving 120 mph during the Black Forest Run tends to put a lot of bugs on the front.
It's not about getting from point A to B, it's about every curve in between.
