I bought a weighted m3 shift knob for it...should make the awesome B&M shift kit more smooth into 1st and 2nd.
~ Kungfu01
1997 328ic, arctic Silver/Black top, 118K, K&N cold air, Borla Exhaust, B&M short shift, Fan delete, UUC underdrive pulleys and Bavauto programmer.
Re-did my headliner in black butter suede!
Perks of owning a bodyshop.
comes from Keystone you may have to find a dealer in your area.
http://www.keystone-auto.com/bodyshops/index.html
cheap Taiwan shit im sure.
i'm about fucking sick of mine. its for sale. who wants it?
-ducky
I got a dolla
painted the rear badge black =]
and started to worry about the clear coat peeling off the back =/
I put mine up on the lift for its first time (with me), and Power-Sprayed the engine bay.
Oil pan gasket leaking onto front sway bar, and insulation around drive-shaft rubbing on drive shaft.
Other than that, everything looked ok. TRUE dual exhaust FTW
Continued trying to replace the hood release cable: Removed bolts on driver's side catch. Couldn't move it enough. Removed bolts on passenger side catch still no luck. Tried to remove little plastic housing in front of the catch. Removed some bolts now it wiggles. Figured maybe if I removed the grill. Drivers side not coming out so I tapped on passenger side. That one came out easy. So now that I know how it comes out, I wrestled with it and got it out too. Nope, still no access. I did notice that now the grill frame is sort of movable....if I remove the bolts over at the end. Now I have to take out the inner fender liner to get those bolts. Done, now I can twist the grill frame a bit and move the catch but still can't unhook the cable. Looks like tomorrow I get to do the other side. Why is it before you do something you have to do something else? Surely there has got to be an easier way to do this. Of course once I get the cable unhooked, I still have to get the new one into the passenger compartment. I can't imagine that will be easy.
I have installed a M3 aluminum pedals (4 pieces) that i baught off Ebay and they look very sharp.. Even my mom said "wow"..
definitely a must have interior upgrade. will post a pic soon
Painted some e39 rims I picked up yesterday.
Did the gas pedal/CEL style fault code read and found out I need a new o2 sensor. secured weather stripping in rear door. Re-secured head unit (it's goin to be a pain in the ass if needed to be removed). Soldered a new contact on break light bulb holder.
I go back and forth about selling mine everyday.
You need to remove the entire nose piece to unhook the cable from the latches. Once that is done cut the rubber grommet off the old cable (where it goes through steel behind the kick panel) then attach the new cable to the old one and carefully pull the new one into place from under the hood. The cone shaped grommet has to enter the hole from the drivers side. Hope this helps.
