So I recently acquired some tan houndstooth door panels, and had a problem. The panels are pearl-beige, and my interior is natur. So I thought I would see if there was a "cheap and easy" way to fix this.
In all of my searching, i could only find people who used vinyl dyes to convert their door panels from some other color to black, or repaint interior pieces that were already black. I did, however, find that a lot of people have good things to say about the Dupli-Color brand. Unlike SEM, you can get it at a lot of local parts stores.
Anyway, Dupli-Color makes 2 different "tan" vinyl dyes.
[1] Medium Beige HVP113
[2] Desert Sand HVP108
This is what the can looks like:
I picked up a can of each and went nuts on a spare natur panel I had lying around:
[Left: Medium Beige] [Middle: typical dirty faded Natur] [Right: Desert Sand]
So it turns out that the Meduim Beige is a pretty damn close match. The Desert sand looks kinda like E30Trash's Mayo wheels. The above photo was taken after the panel sat overnight. Here is a close-up of the Medium Beige area:
I then got some painter's tape to mask off the cloth portions, and started on the rear panels. I cleaned them with some simple green gave them 3 light coats.
One panel masked off before cleaning:
One done, one to go:
Closeup of the end result:
This last photo was taken just after spraying. I think it will lighten a bit overnight. Installed pics + front panels to come.
Nice. Looks like an easy way to TLC some door cards.
I really like that pattern on the insert.
Damn, that's nice and almost exactly what I'm trying for. Where'd you get the cloth?
Looks really good man. Nice job.
You can do amazing things with vinyl spray. I did the centers of the front seats in my 2002, and it held up very well over the 3 years of ownership. They were all black before:
Dieter
What did you use for your 2002? Duplicolor? I can't imagine any kind of spray lasting long through wear.
I got the rear panels installed today, and I can say that I am pretty happy with how they look. They aren't a "perfect" match, but close enough for the $12 that I spent on the dye. I am also not a professional photographer, and the lighting is a bit wierd. My rear seat is also pretty faded. Anyway, you guys be the judge:
Here is a pic of each side:
In this pic you can see the difference in color pretty well. The front panels will match the rear very soon.
Pretty sure it was "SEM" flexible coating. I cleaned the seats with soapy water, dried them and then sprayed many thin layers.
I used the car as my DD and drove about 25K miles in 3 years. I was very surprised that the paint did not wear. Of course it all depends on your weight, size and shape of your behind, I guess ...
Dieter
http://www.vinylprosem.com/page/1285420 and
http://www.tcpglobal.com/autobodydepot/semccaero.aspx
sells it, but I got mine at a local automotive paint shop.
woah! those seats, what style of recaros are those?
and im sure itll fade and match a bit more over time. really digging the houndstooth
I got one of the front panels sprayed and installed. The passenger one needs a little repair before it can be installed.
thats a funky steering wheel lol nice though man
Keeping the arm rest black?
