i like that washer , too. can i see a photo just of the bolt and washer?
i am going to check out these washers. maybe i'll make changes to my product.
thank you for the info, harry
Gerry could make these?
Well anyone could make them, it's a simple enough process. locking tab washers is an elegant and simple solution that should be fine.
+3
Doubt that anyone who is willing and able to work on the cover gaskets/banjos would not be able to make some.
Those who pay to get maintenance done are likely not to care.
Sales look dismal.
CB42613, CB42577, DH29770 and counting...
Ask me...
OK a set of 10 special copper washers will cost about $ 33,-
Orders per PM please, gentlemen , I´ll coordinate it, best would be a group buy/shipping, then the price can be lowered maybe. Not a promise, just an assumption.
But for this option there should be a partner found in the states - who? ;-)
Put me down for 2 sets, Please!
Ok guys. I may sound stupid but what is the reason for this?
Can you explain like for a 8 year old
PS. I want a set for my car. Just need to know what this does.
The Banjo bolts back out, and fall into engine. Oil bar detaches and leaks, reducing pressure. Cam lobes suffer wear.
Acually not into engine, but they can fall into a bad place causing cam/lifter interference.
IS there a problem to mount this??
If you mean is it hard - not really. But it comes with mission creep.
By saying mission creep you mean?
That since a lot of things will be apart, you will be likely to want to open up and fix more things...
I knew that was going to come up. Fatandre, 'mission creep' is when other things come up to do while you have things apart to do the job you set out to do, or that you uncover something that is worn, weak, or broken. Think of it also as 'while I am there I might as well spend the time and/or money to fix that (or those) too'.
Well. the plan is to repair the engine. so I could just do that.
...or
mission creep = scope creep
If one ever manages a project at work, one will often hear those terms interchangeably. Mission creep or scope creep will most of the time end up resulting in delayed completion time, added expenses, and human resources (man hours), etc, etc.
i found the washer. they cost less than a dollar each. PM me and i tell you where to get them.
:-p
Looks like it would be a very nice, clean, and functional application to address the banjo bolt problem. Nice find!
