Just wanted to share with you that Marco in Rockville's '91 850i made 393 RWHP / 352 RWTQ (382/342 corrected) on the dyno yesterday morning.
Adding 60 HP to account for driveline losses suggests that we're right at our target of 450 HP at the crank.
Engine bay photo, dyno graph, and video below.
Congratulation Marco !!!
Click Here For Video...
Rgds...
How much was the total cost
ok...
so where can i buy a kit! either the twin turbo or the supercharger kit! PLEASE PLEASE PLEASE SAY that your going to produce them!
JDM Drift Spec Rx7 --> http://photos.charitymods.org/main.php?g2_itemId=865&g2
Fanta Can 07' Lotus Exige S --> http://photos.charitymods.org/main.php?g2_itemId=79814
Menstrual Red 91' 850i Bavaria -->http://photos.charitymods.org/main.php?g2_itemId=123244
Whoo-wee! Look at that torque curve too! Congrats gentlemen!
Do you have any pic.s of the install on the motor?
Regards,
M.R.
2000 740i Sport Anthrazit Metalic M62TU 4.4 V8/M-Pars 214K Miles!;
2011 Cadillac CTS-V Coupe 6A Raven Black/ 6.2L Supercharged/556HP;
'06 Dodge Magnum SRT-8 Inferno Red/ 6.1L Hemi/ Dyno-368HP / 371lb-ft; ;
SOLD'91 850i Calypso Red M70 5.0 V-12;
SOLD'95 540i Schwartz MetalicM60 4.0 V8;
SOLD'85 635CSi Cosmos BlauM30 3.5 I6;
SOLD'97 Lexus SC400 Maroon/4.0L DOHC V-8.;
1970 Torino. 351C-4V/ 3.71Locker/ C6. Yeah, I'm workin' on it...;
91 Honda CR500 (2stroke,liquid cooled MXer)/230lb/60hp/3.8lb per HP./ FMF Gnarly pipe. Top speed 105mph...in the dirt;
1950 International/Farmall Model-M Top Speed-17mph in 5th. It's a tractor, Bish!
im in rockville, and would love to see it. and i will bring you another one you can start on
Please contact me offline for cost and availability.
smith001@itsystems.net
This is the Stage II Intercooled version. Stage I, which is non-intercooled, will make approx the same HP as a stock CSi.
Thanks for the kind comments. I will post pics of the install on the motor once I get the car back up on the lift.
If you can make it to Alexandria, VA one evening this week - - and assuming that Marco has no objections - - we can take the car out for a spin.
What year is your car? Auto or manual trans? Miles?
Rgds...
I see pipes but the supercharger must be hidden i cant see it
great work!!
Looks very promising. Great job guys!
I will have john comment on the details but I have seen this install and if the air box covers are attached it is hard to tell from stock. The SC is bottom mount and has proper ground clearance.
This is a first rate install and workmanship. Congrats to John on the successful project and Marco on the newfound power.
Marco...Now you need to replace those skinny tires with some fat ones to stop losing traction on all those gears.
Yes. Among the design criteria for the kit were the following:
- Stage I: Achieve CSi HP levels at the crank.
- Stage II: Achieve 450+ HP at the crank.
- Engine bay should appear as close to stock as possible.
- Bolt on installation - ie no cutting of any metal parts in the engine bay.
- No (or minimal) cutting of plastic parts in the engine bay.
- Installation by experienced mechanic possible in less than 8 hours for Stage I and less than 12 hours for Stage II.
I'm happy to report that we achieved all of these goals with the following exceptions:
- Stage I & II: Two oxygen sensor bungs must be welded into the exhaust system just ahead of the catalytic converters. This should require less than one hour of labor by an experienced welder.
- Stage II: A small 3cm hole must be drilled in the plastic shroud just ahead of the radiator to accommodate the oil cooling lines for the supercharger.
- Stage II: The lower black plastic air duct and spoiler must be modified to accommodate the intercooler.
These three plastic bits could be acquired for approx US$300 (see items #2 and #5 here and item #3 here) from Gault for those that wish to retain the option of returning the car to stock in the future.
Just to echo the goal of keeping the engine bay as stock as possible, I would like to mention that it is actually possible to retain the stock air filter boxes if one chose to modify them. However, given that this would require cutting the filter boxes up - - violating the no/minimal cutting design goal - - that possibility was not chosen for the production kits.
Rgds...
Awesome Job, Congrats!
very nice...
i can't wait to see pricing and more photographs.
my car keeps shouting 'charge me, charge me'
I won't discuss pricing or availability in this forum. Please contact me offline for that.
I will try to get more pics posted tonight or tomorrow.
Rgds...
Stelth look Excelent
Very nice. I dream of a stealth s/c for M60 based in C.A.R.B Cali
Here's some pics of the install and some of the parts...
Rgds...
Awesome job, Beautiful/Clean Piping, I'm in for a Fall project, Congrats on a job Well done.
Oh wow nice no ecm mods needed? timing?
John,
Is there any type o boost ignition box, my old vortech s-trim came with a msd-btm box
Best Regards
Bobby B
Although I didn't include a picture of them, ECU chips for the Bosch Motronic are part of the kit also. Here's a listing of the major components...
* Supercharger
* Supercharger Pulley
* Crank Pulley
* Drive Belt for Supercharger
* Spark Plugs
* Spark Plug Gap Gauge
* Intercooler
* Intercooler Mounting brackets
* Supercharger oil cooler
* Supercharger brackets
* Toolkit for specialized fasteners in SC bracket system.
* Air conditioner tensioner pulley
* Supercharger tensioner pulley
* Fuel injectors
* Spark Plugs
* ECU chips
* PCV system components
* Air filter
* Plumbing bits to get from air filter to supercharger
* Plumbing bits to get from supercharger to intercooler
* Plumbing bits to get from intercooler to MAF's
* Plumbing bits to get from MAF's to DK motors.
* Bypass Valve
* All fasteners needed to install the system
* All hoses, clamps, and plenums necessary to install the system.
Rgds...
Looks sick. Are those c30 rotrex, or c38's? You should really post this in the FI section.
― George Orwell
John,
What stage did is on the car, is it a stage I or Stage II?
Best Regards
Bobby B
