Results 1 to 25 of 30
Thread: Best suspension package under $1000?
    Feb 2004
    Utah
    Looking
    Eventually I will want to upgrade my suspension. I am in no hurry to do it, so I am going to take my time researching. What is the best package for under $1000? I will never take the car on the track, but I want a stiffer suspension that makes the car fell more solid during spirited drives.
    Thanks.
    Mar 2001
    Dallas
    98 M3
    hr sports with koni sa's, you might be able to grab sways as well for under 1k.
    Sean
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    Quote Originally Posted by SG_M3
    I agree, and if you are never going to track it, consider getting some 10mm pads for the front. From what I have seen the sports with konis drop you quite a bit.
    Feb 2004
    Utah
    Looking
    Where is the best place to buy those? TMS?
    Mar 2001
    Mandeville, LA
    Z4 M coupe
    How does the HR/koni combo compare with a set of coilovers as far as handling goes? M_azn_3 on this board has a set of FK coilovers and his car handles SICK!!!! There is almost NO body roll at all and the car simply feels like a go kart now. Do I have to get c/o's in order for my car to feel like this or will hr sports and konis do the trick? Im not worried about height adjustablity.
    1/4 mile in 13.1 @ 106++ (calculators put this at 0-60 in "4.21" seconds.)
    Dec 2002
    Southern California
    don't ask
    Quote Originally Posted by xjeeper
    Coilovers just make the car height adjustable, so theres no real advantage of them over regular springs/shocks in terms of stiffness. If this is a street car, skip the coilovers (I am reffering to track oriented ones such as some GC kits) and save a bit of money.
    I say go with Koni's, take your pick of a spring (there are lots of choices), and get an X-brace. The X brace is probably the best bang for the buck mod in terms of suspension you will ever find.
    -Peter
    Current toy: none
    Past cars: 88 M3, 99 M3 x2, 04 M3, 91 NSX, 06 S2000, 01 911TT, 06 Exige, 00 NSX, 04 GT3
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    I doubt H&R sports and konis are going to feel like coilovers, but I could be wrong as I don't know the rates on the COs.
    Quote Originally Posted by m3ster
    X-Shocks.com is where I bought my Konis, I think they were 520 shipped. I bought my springs from Tirerack.com for about 240.
    Nov 2003
    VA
    1997 M3/4/5
    Quote Originally Posted by ///MZG
    What are the 10mm pads for?
    Mar 2003
    Chicago, IL
    1997 M3 Coupe
    One problem that has kept me from definitely going with Koni SAs is the fact that you have to do a bunch of crap to the front strut housing. I'm not sure what exactly is involved with this, but it certainly is off-putting. And speaking of that, is there a detailed write-up anywhere on the exact process of chopping up the front struts to get the Konis in?
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    Quote Originally Posted by Sammyzuko
    I guess I was vague . . . I have seen M3s with H&R sport and Konis be pretty low in the front for street driving (depending on the roads where you live). Some people have added a small spacer to give the front .25 to .5 higher height.
    Mar 2001
    Dallas
    98 M3
    Spring pads are for the rear. H&R sports drop the rear more than the front, so people use bigger pads to bring the rear back up.
    Sean
    Jan 2002
    Raleigh, NC
    H&R Cupkit is an option too, and its cheap.
    -Dan | '99 911 C2 | '02 M3 | '91 318i
    Mar 2001
    Dallas
    98 M3
    doesn't fit m3's.
    Sean
    Sep 2003
    Riverside/San Diego
    95 M3
    check out the new UUC sports suspension it comes with shocks and springs. its about $700.http://www.uucmotorwerks.com/SACHS/
    Dinan supercharged
    Apr 2003
    Florida
    2015 335i MSport
    Im going Bilstein sports and Eibach prokit for my 98
    Jan 2002
    socal
    1995 M3
    how much do spring pads cost? and how hard are they to install? thanks.
    Feb 2004
    Utah
    Looking
    Quote Originally Posted by ////\/\ark
    I definitely don't want to do a lot of crap to my front suspension. I just want something that is plug n' play, so to speak.
    Buffalo NY
    94 318 w/98m3 OBD I motor
    Does anyone have pics of the H&Rsport/ Koni setup. Also does anyone know if 6yl suspension work on a 318.
    Dec 2003
    Bay Area, CA
    1995 M3
    I'de got a GC c/o street kit ready to bolt in with only 7k miles with RSM's you can have them for 900. i've hgot camber plates too , for sale
    Brooks
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    I believe I saw a deal from UUC for $999 for a spring and shock combo WITH the UUC Sway Barbarian kit (front and rear sway bars and rear links). Not sure the quality or ride, but it's under $1000 AND you get sways.
    I actually just got a full GC coilover kit (camber/caster plates, bump stops, externally adjustable, and only used for 2k miles) for $1300 shipped. If that's reasonable to spend, you might spend some time looking around. The deals are out there. You just have to be patient.
    2005 Audi (Purchased 07/09) - 2005 Yamaha R6 (Raven) (Purchased 5/06)
    07/97 BMW (Sold 08/09) - 03/01 Audi A4 1.8TMCX (Sold 06/03)
    Please do NOT PM me! Email me: clumpymold@sbcglobal.net
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    Quote Originally Posted by nathan
    clumpymold : dude i thot u said c/o were over rated? and your daily driver did not need them. ?
    -nathan
    Really? When did I ever say that? What context was it in? That would be odd of me since my last car (see Audi in sig) was my daily driver and I had H&R coilovers. I switched from H&R springs and HIGHLY recommended coilovers. It IS a bit drastic for the street but I like a more lowered look than most spring/shock combos give so coilovers were my only option.
    On top of that, I like the adjustability of it AND I got a great deal.
    Jul 2002
    California
    http://www.druidhillroad.com/koni/
    Feb 2004
    Utah
    Looking
    Quote Originally Posted by clumpymold
    Do you have a link for that?
    Jun 2003
    texas
    M3
    Correct me if I'm wrong here, but:
    Coilovers provide the main advantage of corner weight balancing and ride height adjustability (needed for corner weight). For a street car, it's overkill.
    The flatness or lack of lean/roll is primarily from the sway bar. Stiffer spring/shock contributes a bit.
    For street, HR/Eibach spring /w Koni/Bilstein will do.
    anthony
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    http://forums.bimmerforums.com/forum...&highlight=uuc
    Not sure if it's still valid though.
